Top Plate Against Uneven Beams: Shim Or Not ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 12:03 PM   #1
Rewards Points: 1,062
Question
top plate against uneven beams: shim or not ?
as i started framing my basement apartment, whose ceiling beams are 100 yrs old and not very level one against the other, i am wondering whether i should be shimming the ones that are lifted above the horizontal line between it and the top plate ?
Old 06-12-2008, 01:16 PM   #2
47_47's Avatar
Rewards Points: 62
Shim them tight
47_47 is offline   Reply With Quote
Old 06-12-2008, 01:27 PM   #3
Registered User
Termite's Avatar
If the ceiling beams/joists been there for 100 years, we can assume that the walls you're framing are non-load-bearing walls, correct? Unless the walls you're framing are built for the purpose of supporting them, I see no need or advantage to shimming them.
Old 06-12-2008, 01:47 PM   #4
47_47's Avatar
Rewards Points: 62
I agree with termite, there is no structural need for the shimming, but it is easier to secure the top plate when it is tight to the joist.
Old 06-12-2008, 02:42 PM   #5
Originally Posted by thekctermite View Post
...we can assume that the walls you're framing are non-load-bearing walls...
i think that is correct. the big fat beams are anchored in brick wall slots that are sized accordingly and are suspended in that manner. no, the frame will NOT be bearing the structure over it by no means. it is just to hang drywall and such.
is this what you meant ?
Old 06-12-2008, 03:10 PM   #6
Registered User
Termite's Avatar
Yes it is. They're non-load-bearing. Either way you do it you'll be fine!
Old 06-12-2008, 03:24 PM   #7
awesome ! why do people have problems with TERMITES, i wonder ? come pretty handy to me.
hope you'll be able to make it to my basement warming party in DC from KS ...
Old 06-12-2008, 03:34 PM   #8
Registered User
Termite's Avatar
Thanks for the invite. I'll clear my schedule.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 06:42 PM
New ceiling for uneven beams RogCat Remodeling 4 01-14-2008 05:47 AM
