Old 07-14-2007, 05:09 PM   #1
Top Cap on Deck Railing
How often do I need to put screws in my top cap for my deck railing? Is it best just to do them in the 4x4 posts, or should I go every 16" or maybe 24".
cibula11 is offline   Reply With Quote
Old 07-16-2007, 10:04 AM   #2
The problem with putting screws in from the top is that over time the wood shrinks and water goes down the screw holes and compromises the wood. I would try to design the railing so the screws entered from the bottom.
Ron
Old 07-16-2007, 08:46 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I would suggest that you do it roughly about every 12". The lumber can warp and changes it's shape as it dries, so don't just go by how it looks when you are constructing the deck rail caps and ballustrades.
As far as worrying about screws and screw areas retaining water and comprimising 2x PT cap rails...umm (that's a new one)
..... I wouldn't worry about it.
Pressure Treated lumber is preserved all the way thru the lumber. If screws and screw holes were an issue with PT lumber, you'd see thousands of owners of PT deck boards (screwed and nailed down deck boards) pursuing a classaction lawsuit....which just hasn't happened yet, and will not happen.....
- Build Well -
Old 07-22-2007, 01:07 PM   #4
i agree with him!! just go forward and no need to worry..
citybuilder is offline   Reply With Quote
Old 07-23-2007, 11:13 PM   #5
robertcdf's Avatar
12"-16" but I really did not need to say anything since Atlantic already had.
robertcdf is offline   Reply With Quote
Old 07-25-2007, 07:17 PM   #6
Custom Cabinet Maker
bout the only other thing is to use either ceramic coated or stainless screws. Both Atlantic and Robert probably do this so often it is second nature
skymaster is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 12:34 PM
Deck Railing ? JayI Carpentry 6 09-09-2006 02:37 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
