Top Or Bottom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 08:23 AM   #1
Top Or Bottom
My house was built in 1975. I have a subfloor with ample crawlspace. We reside in south Georgia. Currently my AC ductwork is under the house which is in desperate need of replacing. I have a vaulted ceiling in my living room which does not enable me to run duct work through the ceiling to the 2 adjoining rooms on that end of the house. With all that being said, I was wanting to know which would be more benificial? Ductwork running through the ceiling or putting it back in the floor. I am willing to put a mini split on the end to cool the 2 rooms. The bottom line is I need more air to my living room because of the high ceilings, which in turn holds hot air at the top.
Thanks.
shorty1970 is offline   Reply With Quote
Old 07-22-2010, 10:35 AM   #2
lloydb's Avatar
Personally, I'd keep it in the floor as you have access to the whole house in your crawlspace. Even if I could get ductwork to the other side through the attic, the crawl is still my preference, especially since you have registers already cut into the floor.
lloyd
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
Bottom plates are not pressure treated Richo Building & Construction 10 03-16-2009 06:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
