Tools For Drilling Concrete Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 11:23 AM   #1
Lightbulb
Tools for drilling concrete walls?
I want to drill into my solid concrete walls in my flat so that I can fix my 17" LCD Tv onto the TV mount. I will be requiring 4 x M5*10 screws and 5 x M4*10 screws. The part of the wall where I want to insert the mount is actually the centre beam that goes all the way down through the flats, so I think there maybe a metal beam behind the wall, but not sure how far behind the wall.
What tools do I need apart from the drill?
Types of wall plugs?
Types of drill bits?
diylass is offline   Reply With Quote
Old 12-03-2010, 11:59 AM   #2
Well first off you should use a hammer drill. This will actually "hammer" while it is drilling and make it much easier to drill the holes and hammer drill bits. As for the bolts you have a couple of options. You can either predrill and use concrete screws with washers to hold the bracket on the walls or you can use expanding achors from Hilti (for example).
Also, if you are drilling into a base building structural element, I would get approval from the association before doing so. MOST likely it wont affect anything but then again thats their decisions.
As for "metal" in the wall, you will have to worry about rebar.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 12-03-2010, 12:09 PM   #3
Rewards Points: 5,336
Put the TV on the table. Too much effort to mount it to that wall.
Ron
Old 12-03-2010, 12:20 PM   #4
Angry
Wall mounting
I want it on a wall as I don't want to clog up my bedroom with furniture anymore
Old 12-03-2010, 12:56 PM   #5
It can be done but if you dont have the correct tools, be prepared to rent them. With a standard drill, it will take a while to drill the holes especially if they are a decent bore size.
Old 12-03-2010, 01:20 PM   #6
Rewards Points: 582
You could rent an SDS drill and masonry bits from HSS tool hire in Portsmouth. You will need an HSS drill bit for going through metal.
The concrete column may be steel covered with an inch or 2 of concrete for fire protection, or concrete with re bar.
stuart45 is offline   Reply With Quote
Old 12-03-2010, 01:38 PM   #7
Well it depends. If its a wide flange and you are drilling into the web then you will most likely have more than a couple inches to play with.
Old 12-03-2010, 02:04 PM   #8
You could also try to ramset the mount to the wall. Just make sure the mount is secured well prior to putting tv on mount.
nsanto17 is offline   Reply With Quote
Old 12-03-2010, 02:08 PM   #9
I wouldnt suggest this. Typically the holes in these mounts are 5/16" and the head of a ramset will not be big enough and you can just use a washer.
Stick with concrete screws.
Old 12-03-2010, 02:35 PM   #10
Rewards Points: 582
Good point.
Old 12-03-2010, 07:13 PM   #11
Tapcon screws
mrgins is offline   Reply With Quote
Old 12-03-2010, 07:28 PM   #12
Concrete & Masonry
Rewards Points: 620
Originally Posted by mrgins View Post
Tapcon screws
Agreed, Tapcons with at least 1.25" embedment, if available. A 17" TV doesn't weigh squat.
jomama45 is offline   Reply With Quote
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 12:04 PM
Plastic boxes on concrete basement walls (?) mdos Electrical 12 08-26-2009 03:27 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Concrete slab with hot water heat- Moving walls skizsam Building & Construction 16 04-06-2009 02:08 PM
