Too Much Weight Above RSJ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 08:32 AM   #1
Question
Too much weight above RSJ?
Bedroom being converted into dressing room, with tiles on floor and 6 wardrobes round the edge. Room is directly above rear end of double reception where the adjoining wall was removed a number of years ago and RSJ inserted. Perimeter of the dressing room sits on the perimeter of reception room / RSJ downstairs. Is there a potential problem with the weight of tiles / wardrobes?
Sarias1 is offline   Reply With Quote
Old 03-29-2013, 03:51 PM   #2
Rewards Points: 150
You need an engineer to determine the load that the floor is designed to support and then you need to determine the live load you are imposing. You stated that the lower level underwent an alteration and a steel I Beam installed to support the floor joists. If you have the plans for that alteration they will likely specify the second floor structure and perhaps the design criteria. How large are these wardrobes? Are they larger and heavier than any other furniture that would normally be placed in that room?
TheCamper is offline   Reply With Quote
Using Weight Scale as a switch blackbrawler Electrical 24 03-27-2013 12:50 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Scissor Lift - How Much Weight??? JackOfAllTrades Building & Construction 9 09-08-2008 06:57 AM
Concern about beadboard weight dphardy Carpentry 4 10-12-2007 03:44 PM
