Too Much Slope On Slab Foundation Site - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 04:54 PM   #1
Rewards Points: 276
too much slope on slab foundation site
I am still in the early planning stage, haven't talked to grader yet. But am planning on building a 32' x 36' shop on a slab foundation. The place where I want to locate has a bit of fall from high point to low point (haven't pulled a string and level out but is probaly 3'). Then of course the build-up around outside of low corners where it continues to slope down... Is there a limit on how much is too much fall or is a just a matter of moving alot more dirt? thanks
ugabulldog is offline   Reply With Quote
Old 08-26-2011, 02:04 AM   #2
Rewards Points: 1,092
"Is there a limit on how much is too much fall or is a just a matter of moving alot more dirt?" I don't understand the question. Dig a flat spot, so you pour on undisturbed dirt, not compacted dirt (fill). Compact gravel under the slab, of course. 3 feet? Hell, I just dug down 25' and had to move over 6,000 yards of dirt for my house area. You're flat!
Old 08-26-2011, 08:33 AM   #3
Rewards Points: 276
The high side will be 3' below grade (underground).
Old 08-26-2011, 10:53 AM   #4
Rewards Points: 1,016
If you are trying to use a monolithic slab, you'll needed to escavate a level area and provide for drainage. When you put put a sting and level on it you will probably find it's more unlevel than you think...
____________
Vince
Old 08-26-2011, 11:09 AM   #5
Rewards Points: 5,336
You can handle it a few ways.
1. You will build a block wall above grade. then waterprroof the block on the outside.
Or
2. Dig back a few feet and build a retaining wall into the hill, keeping the soil away from the structure.
Ron
B. Franklin 1759
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
cracked foundation in post tension slab troynsue Building & Construction 1 05-20-2011 04:41 PM
Relocating plumbing - concrete slab foundation vsheetz Building & Construction 17 04-23-2011 05:22 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
