Old 08-03-2007, 12:13 AM   #1
toggle strength
I'm installing a wall mount sink tomorrow with no mounting bracket or blocking. According to the manufacturer no bracket is needed. As far as the wall goes it's 1/2" ply with 1/4" wainscot so I'm considering mounting the sink with 5/16" toggles. The sink only weighs 30lbs. Should 2 5/16" be strong enough? thanks
farrington135 is offline   Reply With Quote
Old 08-03-2007, 06:52 AM   #2
RippySkippy's Avatar
toggle strength
If you have 1/2" ply, why use toggles, why not use some #10 or #12 1-1/4" pan head screws?
RippySkippy is offline   Reply With Quote
Old 08-03-2007, 09:59 PM   #3
Eibwen
toggle strength
The key thing here is what do the mfg's installation instructions recommend?
The sink may only weigh 30 pounds but what if somebody decides to sit on it?
Sammy is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
"High strength Sheet Rock" handyflyer Remodeling 1 02-05-2007 05:51 PM
Toggle switches: With or without grounding screw? Marekus Electrical 3 11-27-2006 04:48 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
