Old 09-15-2008, 08:14 PM   #1
Toe nailing trusses to the top plate?
Is there a accepted way to secure/nail the truss to the top plate?
Or is there a right way versus all other methods?
A friend of mine insist on four 16d through one side and 1 16d on the other???
TonyGG is offline   Reply With Quote
Old 09-15-2008, 09:29 PM   #2
Moderator
Termite's Avatar
It totally depends on the truss, and the required uplift connection. You get about 90 pounds of uplift resistance for every properly installed 16d nail you toenail in. There comes a point where a few nails is too many nails, and compromises the uplift resistance of the truss.
The connection needed is specified for each individual truss on the MiTek or Alpine truss packet (not the layout) that gives the design data for each truss. If the work is being inspected, plan on having that packet there for the inspector.
Personally, I'm a fan of truss clips and three or four toenails max, unless the specs dictate more.
Old 09-15-2008, 10:11 PM   #3
thanks again for your help. I'm going to use the "U" shaped hurricane straps for the final tie in.
I was wondering if there was a general consensus on toe nailing during truss setting day. Of course, I may be over thinking this!
Old 09-15-2008, 10:37 PM   #4
Moderator
Termite's Avatar
You're probably overthinking, but don't exceed 4 or 5 nails in most circumstances. Actually, I forgot about our previous truss discussion...
For your trusses (being 50' long), you'd be smart to get a nice beefy hurricane tie to anchor your trusses. Maybe something more substantial than what I pictured above. Check with your truss guy to see what he suggests!
If you can, take some pictures to show us how you set your trusses and finish your garage/barn!
Old 09-15-2008, 10:40 PM   #5
for sure...
Old 09-15-2008, 10:46 PM   #6
Moderator
Termite's Avatar
In the meantime, I'll keep my fingers crossed for you! Keep 'em all vertical!!!
Old 09-16-2008, 09:11 PM   #7
General Contractor
joasis's Avatar
You may wish to consider that if you do nail 16d's in, and spot 4 of them on 1 side, there is a fine opportunity to split the wood, and that would weaken the truss to wall connection. What we do now is drive a 4 inch torx screw right up through the plates into the truss, and one from each side. The clips get screwed on with 2-1/2 inch torx screws. Never had an inspector look twice.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Building Garage with Engineered Trusses twiles Carpentry 15 06-15-2013 05:16 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
Joists - TGI vs. Web Trusses handy man88 Building & Construction 3 04-02-2007 12:34 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
