Old 11-30-2009, 08:31 AM   #1
toe nailing
Too often I split the wood while toe nailing.
A) What am I doing wrong?
B) Does the stud need to be replaced if there is a split, it may either be at the bottom on the sill or at the top. The splits run from the nails.
sharp is offline   Reply With Quote
Old 11-30-2009, 09:19 AM   #2
Next Time...New Build
toe nailing
Are you hand nailing or using a nail gun?
Try starting the nail higher up the stud and not going at such a steep angle.....sounds like you aren't nailing into enough of the meat of the stud
Also, if you are hand nailing, try dulling the point of your 16d nail before nailing. Flip it over and hit the point with your hammer to flatten the point a little, seems to drive easier without splitting the wood.
Replacing the stud will depend on how much damage is actually done. If you blow out 3/4 of the stud then yes you should replace, but as long as the stud is intact and the structural integrity is not effected, then it is okay. Some wood splitting is inevitable, just make sure the stud is secure.
RickyBobby is offline   Reply With Quote
Old 11-30-2009, 10:03 AM   #3
toe nailing
Thanks,
Was splitting with nail and hammer, didn't work. Switched to framing gun, didn't work.
I do believe I am not getting enough "meat" and my angle is too steep. Will continue trying to get it right. Thanks for the info on the splitting. I don't think any splits are really bad, but I like to keep everything as quality as can be.
Old 11-30-2009, 11:20 AM   #4
Moderator
toe nailing
http://books.google.com/books?id=_CP...age&q=&f=false
Be safe, Gary
Clothes taking longer to dry?
Old 11-30-2009, 11:31 AM   #5
Framing Contractor
toe nailing
Originally Posted by sharp View Post
Thanks,
You're not using 16d's to toenail, are you? If you are, that's your problem.All you need is 8d's for toenailing.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-30-2009, 11:54 AM   #6
Old School
Willie T's Avatar
toe nailing
One trick that will help you is first tap the nail straight in at about 1-3/4" above the plate. It should be in the stud far enough that it will stick there if you let go of it... about a quarter of an inch.
Then you tilt the head upward to your driving angle (around 30 degrees), and drive it on home.
Willie T
Old 11-30-2009, 02:53 PM   #7
toe nailing
Sharp, I just wanted to add that Joe is one of the pros we are blessed to have posting on this site. He is from a region where toenailing wall studs is standard practice so he is very well versed in it. If you've read his other posts you'll find out that he has probably toenailed more lumber in a week (maybe a day) than we'll ever think about.
Old 11-30-2009, 08:30 PM   #8
toe nailing
Thanks for the replies. I will try the new approaches, hope to pick the skill up real soon. Will confirm nail size this week.
Old 12-01-2009, 12:17 AM   #9
toe nailing
Is the wood your using from Home Depot? They are notorious for extremely dry wood, At least the HD's by me are. Extremely dry wood splits pretty easy.
James Con is offline   Reply With Quote
Old 12-10-2009, 10:11 PM   #10
toe nailing
This is getting on my last nerve. I am pretty much a novice when it comes to carpentry things but have helped my dad my entire life. I have now reached my breaking point. What is the correct way to toe nail a 2x4 to an already constructed top 2x4 without it moving or slipping with each hit?? I am not able to nail it in at the correct marking. Its hard already for me to nail things abovet my head, but on an angle, and loose? Ahh, someone help me!!
goalkeep15 is offline   Reply With Quote
Old 12-10-2009, 10:21 PM   #11
Xtreme DIY'r
toe nailing
Nail gun
Or if doing studs you have a scrap piece 14.5" that you put up that pushes against the last stud
That way each stud is 16" OC
Old 12-10-2009, 10:44 PM   #12
Old School
Willie T's Avatar
toe nailing
Sharp,
With some practice, it becomes easy to put the toe of your boot a couple of inches up on the back side of the stud to be nailed. You hold your foot firmly down on the plate and you reach around the stud from one direction with the nail in one hand, and from the other direction with the hammer in that hand. You'll kind of have your shoulder against the back side of the stud. (You're standing behind the stud, and nailing the other side of it.) The stud will move a little, so start about a half inch back from where you hope to end up. But don't worry if you go a little past the line with those first two nails on the one side... because you will be able to move the stud back when you nail the other side.
Another good method of holding a stud in place is to tap in a nail into the plate on the opposite side from where you will be nailing, right up against the side of the stud. That nail will hold the stud pretty much in place, and it is very easy to pull out.
The guy in the picture is NOT using his toe as he needs to be. His toe won't hold a thing the way he has it so far away from the stud... but that's because he has already nailed the side his boot is on.
Click HERE for a sequence of the same sort of pictures.
Willie T
Nailing down engineered wood planks ? Flt_Simulation Flooring 2 05-14-2009 05:36 PM
Nailing up aluminum fascia cover pstasuik Roofing 8 03-19-2009 04:53 PM
Nailing studs to sole plates bluefitness Building & Construction 6 12-15-2008 11:54 PM
Nailing subfloor to rimboard iMisspell Building & Construction 1 10-21-2008 08:43 AM
