Tmr - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:17 AM   #1
tmr
tmr
I bought a home and discovered the hardi plank is attached directly to the exterior studs; no house wrap, no styrofoam insulation , no sheathing. Should I be concerned?"
tmr is offline   Reply With Quote
Old 06-13-2012, 09:21 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
I have sen it done that way before while doing demo on a pre existing structure. if you are located in a humid climate then yes, worry. if you are located in a dry climate then not so much
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
tmr (06-13-2012)
Old 06-13-2012, 09:30 AM   #3
tmr
Thank you. It's in Nashville so I'm a little worried. i don't know how to remedy the problem without just taking off the siding and adding sheathing or at least house wrap. I don't suppose adding house wrap in the interior of the attic would help?
