Tips On How To "raise" A Front Door Threshold - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 11:39 AM   #1
Rewards Points: 173
tips on how to "raise" a front door threshold
whomever installed the front exterior door to my house didnt raise the bottom threshold high enough.. depending on the heat/cold/humidity (regular expansion contraction of framing) sometimes the weather stripping on the bottom of the door will scrape my wood floors as i open it inward. That's how close the bottom of the door is to the floor. (doesnt happen in winter time, but does as we get warmer.. i am assuming its just a wood framing issue).
So my question is.. are there any tricks to "raising" the door before i decide to cut out the door jamb and add one inch to the threshold and then re-install the door?
when i re-did the bay window near the door years ago i discovered significant old termite damage..i wouldnt be shocked if the door has "sunk" a little from termites having a buffet inside my front stoop.. So, long-term solution is take out door and re-install, but wanted to know if there was any shorter term way to gain me half an inch.
(i had already tried putting a spacer in the bottom hinge to "tilt" the door upward as it opens but that didnt work for long)
windowguy is offline   Reply With Quote
Squaring a walkway off the front steps? Boiler98 Building & Construction 3 07-14-2012 08:31 PM
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 09:08 PM
Installing new front door...... Any tips ????? ogoz23 Remodeling 32 05-13-2012 10:10 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 06:08 PM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
