Old 04-16-2011, 04:24 PM   #1
Tips for fixing an out of level concreat floor
I am remodeling a bathroom (approx 8'X8') that is on a concrete slab that is way out of level and has highs and lows in it. It is in the range of 3/4" out of level.
What is the best way to fix this? I assume I need to float a new concrete floor on top of it? Is there a better product that concrete to work with for a job like this?
Should I flash the bottom plate and framing to keep the concrete and future water away from it.
Thanks for any help.
Dave
Dave K is offline   Reply With Quote
Old 04-16-2011, 05:32 PM   #2
Super Moderator
Self leveling compound ---some require a primer on the concrete----Most can be mixed with sand or P-gravel (fills big voids faster and cheaper)
They are a bit tricky to use,as they set up very quickly.
Old 04-17-2011, 08:54 AM   #3
Hi Dave.
1) Find the highest point of the floor.
2) place a laser auto leveler on that point to give you a laser level line on the walls
3) etch the line on the wall with a pencil and a straight edge
4) use a sharp chisel and a 4lb hammer to chip holes into the low laying concrete, this will allow the new concrete a stronger bond
5) mix a skim slurry of 1 part cement and two parts of fine plaster sand
6) ensure that the area to be repaired is scrubbed clean of any oil
7) apply the slurry with a plaster float
8) once done, wait for 30 min and use a longer straight edge to screed the whole surface.
9) you may float - optional
Good luck
Ba080 is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Patching drywall at floor level... daballenger Drywall & Plaster 2 05-07-2010 09:45 AM
How do I level my concrete floor? yummy mummy Building & Construction 33 04-13-2009 12:12 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
Looking for tips on my basement's dirt floor winky Flooring 2 10-23-2005 12:12 AM
