Tin Ceiling Vapor Barrier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 11:56 AM   #1
Learning by Doing
Leah Frances's Avatar
Tin Ceiling vapor barrier?
I have a room below an unfinished attic space that currently has a floor installed in it. Between the ceiling joists are unfaced insulation batts. The former plaster ceiling had to come down. This is a 200 year old house.
- I've been reading an believe I need a vapor barrier. Am I right?
- can I do the foil bubble stuff to add some additional R value? Can I just install the tin ceiling up against the foil? I'm talking about code issues here. I'm sure I 'can' do it. The question is: 'should' I do it.
- I am talking about a REAL tin ceiling, not fake tiles. The tiles interlock (overlapping each other with a 'friction joint' by 1/4 inch) and are screwed to the joists. They are listed by ASTM E 176 and 84 testing as 'CLASS A' or 'TYPE I'. The foil stuff I'm looking at is also rated CLASS A.
Thoughts?
If I could only remember to THINK about what I was doing before I did it.
Last edited by Leah Frances; 05-29-2011 at 08:39 PM. Reason: Adding important details.
Leah Frances is offline   Reply With Quote
Old 05-29-2011, 01:20 PM   #2
Rewards Points: 1,092
True vapor barriers are being shied away from, in all but the coldest spots in the country, and even there they are not always being used. I will not have one in my new house, though the one in my 30 yr old house seems to be working (as are 100,000 others installed between 1980 and now). Check your code yourself, and see if it says "vapor retarder of one perm or less" or "vapor barrier". Air sealing and vapor retarding is the norm now. Whatever you do, air sealing is #1. Were it mine, and code allowed (I bet it does, but check) I would install rigid EPS foam and caulk/tape the seams.
Old 05-29-2011, 02:25 PM   #3
Learning by Doing
Doesn't EPS foam have to be covered by drywall? Or is the tin ceiling the same effect? I'm all about doing what is easy, so long as it is right.
I'm referring to fire rating here.
Old 05-29-2011, 04:42 PM   #4
Rewards Points: 5,336
I wouldn't install the tin ceiling to the joists. I'd put up a sheetrock ceiling on a leveled plane, install 1x3 boards in a grid pattern and install the tin on that. Put a vapor barrier up before the sheetrock.
Ron
Old 05-29-2011, 04:50 PM   #5
** Dunno; check code. People spray foam in attics all the time, and I don't think they rock over them in an attic. I will argue against the vapor barrier; read on buildingscience.com. Vapor open, air tight.
Old 05-29-2011, 04:51 PM   #6
Learning by Doing
Ron
Yes, but do I have to? I mean in respect to the code. I don't see any benefit in sheetrocking the ceiling if I don't have to. Just seems like adding additional layer, cost, time, and effort. If I'm required by code, then I'll do it. But otherwise, what is the justification for adding the layer of sheetrock?
The bottom of the joists are level, the tiles do no require strapping, they are designed to be attached to 16 inch center joists.
Old 05-29-2011, 08:28 PM   #7
I would put a layer of a non combustible surface over the top of wood joists, especially in a 200 year old house.
It's just common sense.
You'd have to check if it's code.
Ron
Old 05-29-2011, 08:31 PM   #8
Learning by Doing
Ron
Yeah local information about code is the best.....
Durn holiday weekend makin' my life harder not easier. Guess I'll have to work on something else 'til tuesday.
Thanks for the advice.
Old 05-29-2011, 08:51 PM   #9
Learning by Doing
Ron
So, I'm digging around and trying to find info about non combustible. I THINK....Sheetrock only qualifies as limited-combustible considered non combustable and from my reading the tin ceiling should also fall into that category for Building Code because of it's rating.
All of this is qualified because I'm not even remotely comfortable with Building Code and NFPA rules. So, yeah, I should call my local Building Code Enforcement folks.
Old 05-30-2011, 10:18 PM   #10
Registered User
Rewards Points: 526
Code doesn’t require one if in Zone 4: http://publicecodes.citation.com/ico...001_par001.htm
R-38 is required: http://publicecodes.citation.com/ico..._11_sec002.htm
No vb: http://publicecodes.citation.com/ico...001_par003.htm
+1/4” plywood is also acceptable without drywall backer; http://publicecodes.citation.com/ico...002_par017.htm
The poly, in my opinion, would trap the warm moist air from below to condense on the tin and rust. You want it to reach the attic (hopefully vented) to escape there.
Check locally…..
Gary
Old 05-31-2011, 09:28 AM   #11
Learning by Doing
Thanks Gary. Great links. Lots of good info.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
