Time For Building A 30 X 28 Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 08:36 PM   #1
Solutions (handyman)
Rewards Points: 364
Time for building a 30 x 28 garage
How long should it take to build a 30 x 28 garage package? The pad is already arranged and paid for, but the rest is a DYI project. I'm looking at three people all with some experience but not pros. The job is building the walls, sheathing, trusses, more sheathing, shingling & siding. Any info would be welcome. I've also heard that a crew to do this would cost $15000 or more, true? It sounds high.
Mark Harvey is offline   Reply With Quote
Old 05-10-2011, 08:49 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Mark,
yes 15k is outrageous. Get yourself one experienced rough framing carpenter and then yourself and a few buddies. If you guys are reasonably adept and able to follow directions, once the pad is in and cured for a few days, you should be able to get the walls and roof on in 1-2 days, including sheathing, not shingles or siding, assuming you are using trusses. Garages are a fun project. Have the women do some cooking and make it a barbecue at the same time.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Mark Harvey (05-11-2011)
Old 05-10-2011, 08:52 PM   #3
Framing Contractor
Rewards Points: 118
A framing price on that is probably about $2000. A few years ago, I helped a friend build his 24x24 garage. It was him (semi skilled) myself, and one of my apprentices. In 10 hours it was framed except for the man door and windows. If you can find even one skilled guy, it will be worth the cost. A lot of the work is unskilled work. Good luck.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Old 05-11-2011, 06:27 AM   #4
DIY staff
Rewards Points: 7,174
What they said----One weekend with a BBQ grill going will get it framed and weathered in---
Siding and trim varies by type and skill---the roof? One day---Mike---
Old 05-11-2011, 02:57 PM   #5
That's a little bigger then mine. Took me one day to lay out the block foundation and anchor it to the pad. One day for framing,one day for roofing and one day for siding and wrapping soffits. Had one guy helping except with the block. Slab was 3K hired out and the materials for the rest was just under 3k. Tax assessor liked it so much they jacked the property value up 12K
The Following User Says Thank You to Marty S. For This Useful Post:
oh'mike (05-13-2011)
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 07:06 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 06:13 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
