Old 01-05-2012, 05:10 PM   #1
timber span
How far can you span a 8x8 10x10 and 12x12?
House mover is offline   Reply With Quote
Old 01-05-2012, 05:29 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
timber span
You can span them in any length you can get them.
That said it doesn't mean you can put anything on top of or hang anything from them.
Is there more to your question?
Andy.
AndyGump is offline   Reply With Quote
Old 01-05-2012, 08:29 PM   #3
Retired carpenter
timber span
Depends on their load. The heavier the load, the shorter the distance they can span. (You didn't ask the right question.)
Right questions:
How much load can an 8x8 hold over a span of 20 feet?
How much can I span an 8x8 supporting a uniform load of 50 psf?
There is a formula to answer those questions. I can look it up if you want.
abracaboom is offline   Reply With Quote
Old 01-05-2012, 08:32 PM   #4
Disabled wood vet
titanoman's Avatar
timber span
I tend to think such lumber is for verticle applications. Heavy beams are more the laminants, Micro and Glu Lams.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 1 10-09-2009 01:24 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
Timber retaining wall repair *Kennedy* Landscaping & Lawn Care 2 03-26-2009 07:02 PM
