Tilt Vinyl Window Is Stuck... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 09:39 AM   #1
Tilt vinyl window is stuck...
The top half of a tilt vinyl window is stuck. It will not come down even an inch in order to tilt it in for cleaning. What can I do?
STUCK is offline   Reply With Quote
Old 10-02-2010, 07:41 PM   #2
Are they double hung type sash windows? Not all of those are actually true double hung windows (so the tops don't move.) I only mention this because I only recently found this out when I bought a place with a whole bunch of mismatched replacement windows installed.
1910NE is offline   Reply With Quote
Old 10-02-2010, 07:50 PM   #3
Rewards Points: 5,336
Are you sure it's not a single hung window? Do the other upper sashes move?
Ron
Stuck Tilt In Window cs006b Building & Construction 1 08-25-2009 07:04 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
