Tiling Up To Door Molding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 10:31 AM   #1
Rewards Points: 81
Tiling up to door molding
I'm getting ready to tile around my tub, and right at the edge of the tub starts the door molding. I'm wondering what to do there -- should I take the molding off, remove the drywall under it, and put the backerboard in it's place under the molding? Or should I just put the backerboard right up to the edge of the molding? Do I then caulk the tile to the molding or leave a little gap?
thanks!
99miles is offline   Reply With Quote
Old 08-10-2009, 11:11 AM   #2
Registered User
Termite's Avatar
You should cut the door moulding. The good news is that you can do it without removing the moulding. You can buy an inexpensive jamb saw at Home Depot for under $20. It flush-cuts with the floor...Lay a tile (loose) on the floor to use as a guide to rest the saw on and cut the bottom of the casing out, as well as any part of the jamb that will abut the tile. That way your tile is under the wood and it doesn't have a goofy groutline appearance.
There are also powered ones available for rental or purchase:
Old 08-10-2009, 11:17 AM   #3
Rewards Points: 81
Sorry, I wasn't clear. I'll be tiling on the wall, above the tub.
Old 08-10-2009, 11:21 AM   #4
Registered User
Termite's Avatar
Ahh, got it. Leave the sheetrock under the moulding alone. Cut your sheetrock an inch or so back from the moulding and install backerboard there. That way the seam is covered by a tile and you don't have to disturb the moulding. You'll probably have to add a stud or two to support the seam and give you something to fasten the edge of the rock and the edge of the backerboard to...Two studs is easier, or a flat single stud.
You can caulk the tile to the wood moulding when completed.
Old 08-10-2009, 09:48 PM   #5
Rewards Points: 81
Thank you so much for your detailed responses! I think I get it now!
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
bathroom tiling neptunian General DIY Discussions 1 03-29-2005 07:44 AM
