Tiling Shower Walls Help - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 04:34 PM   #31
"You can do anything"-Mom
brockmiera's Avatar
Originally Posted by JazMan View Post
So the shower floor is 32"x60" and the drain is centered right?
Jaz
Yes that is correct.
On a side note. The previous owner must have been a concrete finisher or something. We got a great stamped patio but a VERY sloped concrete floor. Can I use deck mud to make the floor level?
brockmiera is offline   Reply With Quote
Old 02-14-2013, 05:00 PM   #32
Tileguy
JazMan's Avatar
Rewards Points: 422
Which floor, the bathroom and shower area? Yes you can, but it'll need to be bonded and minimum 3/4" or so making it kinda thick where it slopes. Self leveling is another way and may be better cuz it can go from 0 to and inch or more.
Jaz
Old 02-14-2013, 05:06 PM   #33
brockmiera's Avatar
Jaz
It would be just the shower area. The bathroom floor is pretty level now. I'll take measurement in an hour or so when I get home. I don't know if if is more than an inch out of level.
I'll probably just do the self leveling stuff. Before that I need to replace the P trap and drain pipe, back fill with gravel or squeege. I was thinking about placing a 3-4" or so form around the drain pipe so the self leveling doesn't come into contact with the new pvc. Then fill in the area left with some deck mud.
Old 02-17-2013, 03:36 PM   #34
brockmiera's Avatar
Ok so it looks like the slope was 1 1/2. So I can do one of two thing. Use sand mix to make the slope a little more gentle or level the whole thing and then make the shower pan on top of that. Any thoughts?
Replacement tiling in bathroom on damaged walls JeanB Tiling, ceramics, marble 0 04-20-2012 09:52 PM
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
Ideas for shower stall walls moneymgmt Building & Construction 15 09-01-2010 01:48 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 07:40 PM
