02-13-2013, 09:54 PM
#16
"You can do anything"-Mom
Tiling Shower Walls Help
Originally Posted by JazMan
Yeah that woulda been a good way to go. Lets say i already have 1/2" xps on the wall. What could I do now?
02-13-2013, 10:05 PM
#17
Tileguy
I would spend 10 minutes and remove the xps and continue with Kerdi Board. Or, install furring either 1x3 -4 or 2x4's flat and then go with wallboard and Kerdi membrane or concrete backer and then Kerdi fabric or other waterproofing method.
I didn't read your intentions, so what method of tile installation are you planning?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
02-13-2013, 10:27 PM
#18
Jaz
Kerdi membrane over the xps is what i was planning. I can kerdi over the wall. Where can I get kerdi board?
02-13-2013, 10:51 PM
#19
Tileguy
I have no idea if unmodified, (or even modified) will bond well and if xps is a suitable substrate, never had to do that.
I found 8-10 dealers that claim to be Schluter retailers. But I doubt any carry the board. They'd have to order it from the distributor. Best to call Schluter to see if they know which distributor stocks Kerdi Board.
United States of America
Schluter-Systems L.P.
194, Pleasant Ridge Road
Plattsburgh, NY 12901-5841
Phone: 1-800-472-4588
Tell them hey for me.
Jaz
02-13-2013, 10:57 PM
#20
Jaz
Can do. Thanks Jazman
02-14-2013, 10:38 AM
#21
Newbie Bill
So he could do the Kerdi board right over the concrete wall?
Bill
A DIY Noob that knows just enough to be dangerous.
02-14-2013, 10:52 AM
#22
Yeah thats what it looks like. Have you priced Kerdi board? I'm sure it is the best stuff out there but dang....Back to the drawing board.
I think I will still take down the XPS and just use furring strips with hardibacker then use the kerdi membrane that comes with the whole shower kit. The kerdi liner will serve as a water barrier from not only the inside but the outside as well.
02-14-2013, 11:39 AM
#23
Tileguy
How much did you expect it to cost? It allows you to eliminate the furring strips, the concrete backer and the Kerdi Membrane. Not to mention the other materials that go with them and the labor. Yes, it's not cheap, but shouldn't expect it to be. It also depends on what you have to pay for it of course. You've gonna pay a little more than me. I'd say anything close to $100 a sheet retail is a good deal.
Jaz
02-14-2013, 11:54 AM
#24
Jaz
So that would be about 200 for the wall. No extra for the thinset because I will need it anyway.
we are looking at about 20 buck for the furring strips, 8 for the tap cons, and 16 for the backer board.
Labor is free
The kerdi membrane is included in the $400 kit I am getting with the shower pan and drain.
I respect what your opinion but it also needs to make sense to my budget. I'll call this capco tile place that Schluter said was my closes dealer and price it out and go from there. I'd like to use it though. It was going to be my first choice and may end up being the last choice.
02-14-2013, 01:56 PM
#25
Tileguy
It's probably too expensive for your case since you've already committed to going another way and have those materials.
The Kerdi Board sheets I referred to are 4x8. On the kit you bought, you coulda bought just the tray and the fabric for less $. You did it that way for convenience. So go with the extra free labor route, it'll work just fine.
Jaz
02-14-2013, 02:49 PM
#26
Jaz
Well I haven't bought any of the furring strips, tap cons, kerdi kit, or anything. I just spend way too much time pricing things online and at the home improvement stores. I'm game to do whatever is going to be a good way to do it. Obviously cost is a concern but if its only a hundred bucks one way or the other then lets go with the easiest and most complete.
02-14-2013, 02:51 PM
#27
Jaz
So if I buy just the tray and liner separate, what kind of drain do I go with?
If I decide to use just the drain and liner will they work with a mortar bed?
02-14-2013, 03:48 PM
#28
Tileguy
Sorry, yes you want and need the Kerdi Drain too.
Yes, that's the way most of the showers are built by the pros. The tray makes it easier if the size works out for you. The tray is a good idea for DIY. What size is your shower floor again?
Jaz
02-14-2013, 03:52 PM
#29
Jaz
I'm planning on it being 32"x60" because of the premade Kerdi shower pan. I am going to frame a 12" bench to make the over all shower 32"x72"
02-14-2013, 05:08 PM
#30
Tileguy
So the shower floor is 32"x60" and the drain is centered right?
Jaz
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
