Tiling Shower Walls Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 11:51 AM   #1
"You can do anything"-Mom
brockmiera's Avatar
Ok so here is the situation. I am renovating a basement bathroom. I took it down to nothing and have built it up. The shower will be two framed walls and one exterior concrete wall.
the previous owner had taken mastic right to the concrete walls and attached the tiles. I scraped it all off with the thought that I would do 1/2" XPS, Kerdi liner over that and tile directly to that.
The reason I want to do this instead of framing a wall there is because of space. I dont have an extra 4" because of where the toilet flange is set and I dont want to move the toilet if I dont have to.
I got to thinking last night while I was looking at the xps. Will the tile cause the XPS to separate from the wall?
What do the experts think I should do?
brockmiera is offline   Reply With Quote
Old 02-13-2013, 11:54 AM   #2
brockmiera's Avatar
Here are some pics.
Tiling Shower Walls Help-2013-02-10-18.32.31.jpg   Tiling Shower Walls Help-2013-02-10-18.32.57.jpg
Old 02-13-2013, 02:23 PM   #3
brockmiera's Avatar
One thought I had was to attach a few 1x3's to the concrete wall thru the XPS. I dont know if I need them but I'd sure hate to have that nice tile start pulling away from the concrete wall.
Old 02-13-2013, 02:53 PM   #4
Newbie Bill
Rewards Points: 518
I am just guessing, but I don't think you would get any longevity by tiling directly onto the xps.
Could you put the 1X3's on the wall, tapconed thru the xps to the concrete, then apply concrete backer board to the 1X3s, then do the tiling?
Again, I'm just guessing. Hopefully my silly ideas will bring out an expert or two.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-13-2013, 03:19 PM   #5
brockmiera's Avatar
Yeah for some reason I thought that glue would be enough. Maybe because of how amazingly hard it was to get those other tiles off the wall. But I think you are right.
I'll probably end up using 1x3's and framing the wall.
In order to keep the wall to a minimum thickness, do you think I can get away with 1/4" backerboard?
Old 02-13-2013, 03:38 PM   #6
Newbie Bill
Rewards Points: 518
We need Bud or Jazman to comment on that.
Bill
Old 02-13-2013, 04:09 PM   #7
brockmiera's Avatar
No joke. Where is Jazman when you need him.
Old 02-13-2013, 04:35 PM   #8
Newbie Bill
Rewards Points: 518
I sent him a PM to ensure he shares his thoughts with us when he logs on.
Bill
The Following User Says Thank You to drtbk4ever For This Useful Post:
brockmiera (02-13-2013)
Old 02-13-2013, 05:42 PM   #9
Rewards Points: 12,808
No way is tile going to work out just stuck to foam!
Old 02-13-2013, 05:45 PM   #10
brockmiera's Avatar
Ok thats three votes against my original thought. How now should I go about fixing it?
Do you think 1x3's tapcon'd to the concrete wall and nailed to the sill plate will work as framing?
Old 02-13-2013, 06:15 PM   #11
Newbie Bill
Rewards Points: 518
Come on Joe, provide some ideas please.
Bill
Old 02-13-2013, 07:42 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 218
Here I is!
If you fir out, You may want to go thicker than 1x3" It's only 3/4 thick.
But.......how about Kerdi Board?????? It's made for just this type of job.
Take a look. This should solve your problems.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
drtbk4ever (02-13-2013)
Old 02-13-2013, 07:50 PM   #13
brockmiera's Avatar
Originally Posted by JazMan View Post
JazMan
Thats all we get today???
The Following User Says Thank You to brockmiera For This Useful Post:
JazMan (02-13-2013)
Old 02-13-2013, 07:57 PM   #14
Newbie Bill
Rewards Points: 518
Here I is!
Jaz
See, I knew we needed Jazman's help.
Bill
JazMan (02-13-2013)
Old 02-13-2013, 08:02 PM   #15
Tileguy
JazMan's Avatar
Rewards Points: 218
Also try this:
Jaz
Replacement tiling in bathroom on damaged walls JeanB Tiling, ceramics, marble 0 04-20-2012 10:52 PM
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 05:56 PM
Ideas for shower stall walls moneymgmt Building & Construction 15 09-01-2010 02:48 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 01:44 PM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 08:40 PM
