Tiling Shower To A Kohler Receptor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 05:43 PM   #1
Tiling shower to a Kohler Receptor
Since there is no tile section I figured I would put this here. Below you can see a diagram from the instructions of the Kohler cast iron shower receptor that I have. It shows the tile stopping rather high up. Is this the proper way to do this? I assume I would have to go get bullnose for this?
Aren't you supposed to bring the tile down past the lip to the top of the tub (or in my case, receptor)? I measured the lip, If I use the 1/2" cement board that I bought the tile will hit the lip before it reaches the top of the tub.
Any help?
Thanks...
Lockeset is offline   Reply With Quote
Old 11-13-2010, 05:52 PM   #2
I found something wrong with that image above, the lip is not 5/8" high, it is 1 3/16" high as shown in another spot in the instructions.
Old 11-13-2010, 07:40 PM   #3
Rewards Points: 5,336
Shim the wall out so the cement board drops down past the receptor edge by at least 3/4". The tile should extend down to 1/8" off the receptor bottom. Silicone caulk the cement board. Silicone the tile to the receptor base.
Ron
Old 11-13-2010, 10:23 PM   #4
Ron
My concern is why Kohler says to leave the tile so high off of the receptor. Is this common at all? Has anyone ever seen tile done like that?
Old 11-13-2010, 11:01 PM   #5
firehawkmph's Avatar
Rewards Points: 1,868
Lock,
Regardless of the discrepancy in heights in your two diagrams, it looks like they want you to just extend the tile slightly past the top lip of the base, and then caulk the joint between the tile and base. I think the drawing is exagerated a little. Keeping the tile up off the bottom of the base will probably help the longevity of that joint, it won't be sitting in water all the time that the shower is in use. I would shim the cement board as necessary to make if flush with the shower base lip, then extend the tile just below the joint and caulk it like they show.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-14-2010, 04:17 AM   #6
Thanks for the reply. If I do that, I would need to get bullnose tile, correct?
Old 11-14-2010, 07:13 AM   #7
ccarlisle's Avatar
You think a DIY board doesn't have a tile section?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
Last edited by beenthere; 11-14-2010 at 07:57 AM. Reason: removed uncalled for emark
ccarlisle is offline   Reply With Quote
Old 11-14-2010, 07:54 AM   #8
Are you kidding me???
Last edited by beenthere; 11-14-2010 at 07:58 AM. Reason: Removed quote of insult, uncalled for reply
Old 11-14-2010, 07:58 AM   #9
An old Tradesmen
Rewards Points: 6,932
Try respecting all members. Those types of comments aren't allowed.
Old 11-14-2010, 08:06 AM   #10
FWIW, the only tile section I found was part of a barely used subforum under the Flooring forum, which my question doesn't apply to.
Old 11-14-2010, 10:48 AM   #11
Lock,
If the bullnose are available, it would make for a nicer joint. I would also caulk between the cement board and the tile base right where they meet before I put the tile on. Make sure it is a nice tight bead, don't get sloppy with it, just as a secondary seal.
Mike Hawkins
Old 11-14-2010, 04:43 PM   #12
Excellent, I appreciate your input. This just seemed so odd of a way to do it, all the other tubs I have ever seen had the tile brought down past the lip to the top of the tub.
I actually like the way Kohler is saying to do it, I'll have a nice (easy to clean) edge around the entire way instead of the tile sitting in the water.
Old 05-04-2011, 07:43 AM   #13
Just curious to know how the install went
I purchased the same receptor and ran into the same issue. My tile guy wants me to bring the durock down into the pan leaving about 1/8" off of the pan floor. He doesn't think the tile will look right if we follow the instructions that Kohler provided. I found a picture of a job someone did using the Kohler receptor and it looks like he goes right down into the pan as well.
Just curious to know how your job ended up.
Thanks,
Greg
gregory99 is offline   Reply With Quote
Old 07-27-2011, 01:01 PM   #14
tiling around shower receptor
I, too, am getting ready to do this. Appreciated some first-hand experience!
Karen
ksprn51 is offline   Reply With Quote
Old 12-04-2011, 12:34 PM   #15
Mark Daniels Kichen &Bath
The tile job with the Kohler cast iron pan is mine. Reaching over the flange is a stretch especially if your wall to wall is over 5ft. You can notch the back wall studs or pad them out a 1/2" to get your tile to fall well inside in the pan. The ends wall are more of a problem. You can "thick set" your tile and grind an angle on the back side of your bottom edge of your tile to get them in. Better yet if you can pad one of your end walls out 1/2" of so.
Mark Daniels Kitchen and Bath Remodeling
Niches
Mark Daniels is offline   Reply With Quote
Sterling Kohler Advantage 6203 Shower Problem striper Plumbing 4 08-15-2010 02:32 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kohler shower door, tolerances, not sure which size to pick mslide Kitchen & Bath Remodeling 2 12-04-2009 11:08 PM
Tiling over greenboard outside shower area toocheaptohire Remodeling 4 04-10-2009 08:42 AM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 07:40 PM
