Tiling A Porch Over A Painted Concrete Surface - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 07:38 PM   #1
Tiling a porch over a painted concrete surface
I wish to lay tiles on my front porch. The concrete was painted, over 10 years ago. The paint was flaking in some areas and there was bare concrete in others, and I was told to scrape all loose paint off; then, sand the entire area (including steps) with very coarse sandpaper. I have done this. I have then painted the entire area with Bondcrete- first layer Boncrete 1 part to 4 parts water, second layer, 4 parts Bondcrete to 1 part water. My question is, is this enough prep work BEFORE I try to lay the tiles?
OR, should I sandblast or try to remove the old paint completely with paint remover?
Harls is offline   Reply With Quote
Old 07-14-2008, 07:34 AM   #2
depending on your geography's weather, exterior tile may be an exercise in futility,,, even here in ga, its not recommended as permanent 'cause of freeze/thaw,,, there isn't any paint that'll adhere permanently to conc however there are coatings that last.
whoever gave you that advice was probably a painter you don't have to s/b as a grinder & diamond turbo wheel're the best tool choice for prep.
if 10 yrs is sufficient for you, tho, paint it.
yesitsconcrete is offline   Reply With Quote
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 6 04-01-2010 06:41 PM
forming shallow holes in surface of wet concrete mx13 Building & Construction 1 04-25-2008 09:59 PM
forming holes in surface of wet concrete mx13 Landscaping & Lawn Care 1 04-25-2008 05:06 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 10:50 AM
How can I remove an old concrete porch? drh Building & Construction 13 12-11-2007 03:39 PM
