Tile Work (cleaning Gap) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 04:53 PM   #1
Solutions (handyman)
Rewards Points: 364
Tile work (cleaning gap)
A small job that I am doing is grouting some previously laid floor tile. Some of the spaces have excess mortar that, I think, should be removed. Two questions. Is it necessary to remove all the excess mortar ... down to the subfloor? Is there a "power tool" that I can use to grind away the mortar? I'm thinking of a dremel, but is there a special type of bit? Any other suggestions are welcome.
Thanks.
Mark Harvey is offline   Reply With Quote
Old 03-26-2010, 06:05 PM   #2
will be very dusty but dremel will work..sorry don't recall the bit.
have you tried an old screw driver...work it like a chisel...?
Big Bob is offline   Reply With Quote
Old 03-26-2010, 09:19 PM   #3
Rewards Points: 5,336
Thanks.
The interface between the grout and the glazed tile surface is pretty fragile. Be aware trying to remove the grout could seriously damage the tile.
Ron
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
Cleaning ceramic tile surfaces hexland Flooring 2 07-31-2006 10:24 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
