Tile To Tub Transition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 07:56 PM   #1
Tile to tub transition
Has anyone used the Schluter Dilex-AS trim piece for the the tub to tile joint? I have been through two different caulks(DAP and GE) and both have failed after a few months. I filled the tub and let each cure 24 hours before use, but both came loose from the tub. I'm ready to tear the entire tile job out because I want to get rid of the shower doors and am just looking for a better way to seal this joint.
jerryh3 is offline   Reply With Quote
Old 03-02-2009, 10:07 PM   #2
Rewards Points: 5,336
The caulk needs to be 100% silicone and the surface it's put on needs to be clean and dry. Not towel dry, hair dryer hot dry.
I've never had an issue with a fresh tube of GE silicone caulk.
Ron
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Hardwood to tile transition DIY-Renovator Flooring 3 07-06-2008 01:44 PM
Marble to Ceramic tile transition stormsurfin Flooring 3 06-18-2008 10:46 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 05:25 PM
carpet to tile transition jeeper36 Flooring 1 10-26-2007 10:16 PM
