Old 11-03-2009, 11:54 PM   #16
Knucklez's Avatar
i did a similar project as you and documented every step here:
my shower project, denshield backerboard, tiled walls
hope you can find something useful.
Knucklez
"if you can't be handsome, at least you can be handy"
Knucklez is offline   Reply With Quote
Old 11-04-2009, 08:18 AM   #17
ccarlisle's Avatar
Oh yeah, I hear ya, ephnright. Look I'm still showering every morning in the same original shower the builders put into my house back in 1960! OK, a few minor leaks here and there - but the construction was the old plaster-and-lath everywhere and one of the three coats of plaster was good enough in those days to provide sufficient waterproofing. And over the years with regrouting and all, it has stood the test of time.
But nowadays, showers are built out of regular gyproc, maybe cbu and most are tiled over. Greenboard wasn't the answer, more people are taking longer and harder showers and, while grout still leaks, the drainage - and therefore drying - of the surface underneath the tiles is less than adequate, and the water and water vapour behind them causes mould. And most showers are like the one you made, are still being made and will continue to be so.
But time and labour are different these days and people are looking more and more towards professionals to build them a shower that'll last and not create mould. House are tighter, allergies and asthma are up so it's become a health issue almost.
Nowadays, we have the technology to make showers outlast the occupants by 20+ years, it's cost effective and doable, so it is getting done. Membranes are becoming the minimum code for installers who do not want a call-back in their lifetime. Schluter, Noble, RedGuard are all becoming very familiar words not only with installers who keep up with the technology - but with homeowners...as the other forum will testify.
Used to be a time when 4"x4" tiles were the standard because they were cheap at 4 cents each. Nowadays people think nothing of $20 travertine, marble or soapstone...some even drop $12 on slate...so it's no longer cheap to replace it. And what's the same cause? moisture.
Hence waterproofing. I'm not knocking you or what you have done - just looking at it from a different viewpoint.
ccarlisle is offline   Reply With Quote
Old 11-04-2009, 04:53 PM   #18
For those of you interested there is a material called Hercules which is a available thrugh certain upholsterers or folks who make awnings and such. It is a very heavy platic type material with a nylon thread mesh throughout it. The name tells all: it is virtually indestructable and completely waterproof. In a way it is a type of membrane. I made a new cover for my 20x10 portable garage and it has been several hard Canadian winters and the re;s not so much as a scratch on it. I'm bringing this up as a possible replacement for the membrane if it stops being sold nut some research would be needed in regards to an adhesive. I have used a waterproof contact cement with it successfully. It is the same adhesive used to attached landau tops on cars.
Wicked
wicked is offline   Reply With Quote
Old 11-05-2009, 10:35 AM   #19
Originally Posted by wbw View Post
Just been to HD and was told that they are probably going to phase out the membrane (orange stuff) for the walls. The guy there suggested a paint-on membrane: liquid rubber. Anyone hear of this new stuff? will it hold heavy tiles 12 in. by 12 in. or larger? Seems to get more confusing each day, and I really do not want to redo in five years or less since I am redoing it in 4 months or less right now!
What the HD guy is talking about is called RedGard Waterproofing and Crack Prevention Membrane. HD sells it. It isn't really new. It can be rolled, troweled, or sprayed on. There's also a similar product called Mapelastic HPG.
More On This Topic
Small Bathroom Renovation
Small Bathroom Renovation by Expert Village
So this is our second bathroom, and this is the bathroom right off the master bedroom. In this bathroom, the main things we did with the home renovation are that we put in the shower, and I love the shower that it doesn’t have a shower curtain, so... Read More »
Spanish tile has been used for centuries on roofs, and some of these old, historical roofs are still in existence. There are times when repairing a Spanish tile is necessary. Read this eHow to learn more. Read More »
One of the best changes or upgrades you can make to your home is adding or changing the tile in your kitchen or bathroom. Before you can begin this type of upgrade, you must first buy your tile. Read More »
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality assurance walk through on this house. The same thing on this tile we were talking about over here, look for that same thing in your... Read More »
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 11 06-08-2009 09:28 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 04:32 PM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 02:09 AM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 04:30 PM
Drywall or Denshield behind Shower Walls? atilla137 Plumbing 3 07-20-2008 11:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
