#1 |
Tile over laminate backsplash?
I am replacing my countertop but the backsplash is also the same material of laminate countertop glued onto the wall. It is 1 inch thick. I debated taking it out but the electrical socket box extends as far out as the 1 inch laminate and I cannot push it in further.
The laminate backsplash is very smooth. Will a "latex modified grout" hold up glass tile if I try to put it over the laminate? |
#2 |
AHH, SPANS!!!
did you test to see if the electricity is to the plug?
#3 |
Yes, the outlets work. I looks like the "countertop backsplash" and the electric sockets were put in at the same time.
#4 |
AHH, SPANS!!!
at 1" thick you couldn't ask for a stronger wall to put the tile on, but I'm not sure about the surface of the laminate being adhere-able without some type of modification.
#5 |
The laminate backsplash is very strong and sturdy. It would definitely support the tile. However, I've tried sanding it with 60grit sandpaper to make it more course but it is not even affected. I wonder if the thinset will stick to it.
#6 |
Coconut Pete's paella!
Just shut off the breaker, pull the outlet, rip the crap down and reinstall a new box if you are worried about it. I have no idea if tile would stick to laminate .... my sixth sense tells me no, but what the hell do I know. Moving the box should be easy though. TURN OFF the breaker first.
| Display Modes | |
| Starting tile backsplash half-way up wall | dalepres | Kitchen & Bath Remodeling | 3 | 09-13-2011 10:04 PM |
| Travertine Tile Help | MikeinTexas | Flooring | 1 | 09-07-2011 11:43 AM |
| Bathroom tile installation | demolition | Kitchen & Bath Remodeling | 4 | 04-10-2011 08:48 PM |
| Kitchen - tile backsplash grout | Museseek | Tiling, ceramics, marble | 3 | 03-14-2010 01:52 PM |
| Counter top plastic laminate | Gerry Kiernan | Interior Decorating | 4 | 10-13-2008 11:44 AM |
