Tile / Modified Thinset - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 02:12 PM   #1
Tile / modified thinset
Hi,
quick question about the shrink rate of modified thinset ... when tiling around an electrical outlet box ... re; mounting electrical box ... it is suggested to mount box on stud so that it will be flush with finished wall ... ie; if using 1/2" hardibacker and 1/4" tile and 1/4" layer of modified thinset (trowel) ... how much will thinset reduce down ... or ... shrink ... as it is compressed ... when mounting the tile ... and once it is set and cured ??? Ideally ... looking to find out how far out from stud I should mount electrical box ... so as ... when finished ... it won't be to far in ... or ... to far out ???
misguydead is offline   Reply With Quote
Old 09-28-2011, 03:03 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 850
1/4" Of Thinset? Do you mean your using a 1/4" trowl?
When you press the tile one, you compress the thinset so it's not that thick....I would say that when it's all done, thinset adds maybe 1/8". Give or take a few inches....
In your case, I would consider using a mud ring on that box. Most outlet boxes don't like sticking out more than 3/4"....especially if your using the plastic ones with the nails. That is where the mud ring comes in handy....set the box...install mud ring...should be just about right.
Old 09-28-2011, 07:19 AM   #3
Thanks for your reply ... yes ... would be using a 1/4" trowel. right ... not that thick ... but ... give or take a few inches ??? What is a mud ring?
Old 09-28-2011, 07:44 AM   #4
Rewards Points: 150
Thats funny, if you worried just instal a cut in box later.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 11:34 AM   #5
Rewards Points: 79
Whether it's beneath the underlayment, or just the tile, 1/4" notched trowel used at 45 degree angle ends up being 1/8th inch. If you're doing a glass tile - as with back splashes,I've had great success with the 3\16" V notched trowel. Also, if your boxes are plastic, anything extending can be easily removedwith a hand held 4" grinder. Carefully!! or a hot knife.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Thinset Breaking remodeltime Flooring 13 08-04-2011 03:20 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
Terra Cotta tile questions... cocobolo Tiling, ceramics, marble 7 06-04-2010 06:48 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
