Tiger Spray Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 02:26 PM   #1
Rewards Points: 640
Tiger Spray Foam
well I am looking at doing spray foam on my rim joist, since its been a pain in the butt to do it with XPS in some of the smaller spots..... was looking at the home kits Tiger foam sells fast and slow rise (I'd assume I want fast because this isn't an enclosed space behind walls... just the rim joist with the one open end... but their small kit does 200 board ft. at 1 inch... now if I just wanted to seal this up and make it air tight with what R-6 at 1" would this be enough to do this house?
I have walls at that total in length to 190 ft long... when you take out the width of the 2x10's the joists are made of the cavity is about 9 inches high and ~13? inches long... do you think I could get away with one kit just to seal this up? or am I looking at the 600 board ft kit?
Was thinking fill it with at least 1" of spray foam to seal it off and top it off with fiberglass insulation to fill any space left
BlueBSH is offline   Reply With Quote
Tags
spray foam
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 12:58 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-01-2009 11:40 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
