Old 02-26-2012, 10:07 AM   #1
tieing in rafter and ceiling joist
closing in my patio the rafters are 2x6 and should be at least 2x8,i'm putting in 2x6 ceiling joist right under the rafters. what is the best way to tie the two together to give me the best rafter joist strenght.
codeman1024 is offline   Reply With Quote
Old 02-26-2012, 10:16 AM   #2
Stay-at-home GC
Do you mean they are undersized already?
Do you mean you are "stacking" joists directly underneath your rafters (most likely impossible, depending on the depth of your "birdsmouth") as opposed to offsetting them .75" and resting them on the top plate (standard practice)
Pictures?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-26-2012, 01:50 PM   #3
Moderator
"what is the best way to tie the two together to give me the best rafter joist strenght."----- last Table chart, bottom of page: http://publicecodes.citation.com/ico...002_par023.htm
Gary
P.S.- Welcome to the forums!
Clothes taking longer to dry?
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 04:02 PM
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 08:16 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
