Threshold Covering - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 11:36 AM   #1
Threshold covering
Hello,
The door and wooden threshold for my walk-out cellar are exposed to the elements. I've noticed that the threshold has taken a beating and appears ready to crack on a seem. I was thinking of covering the threshold with some sort of protective covering that would keep the rain/snow off. Is there some sort of product that would accomplish this? I don't want to replace the threshold, as, other than for the potential for splitting, it's in good shape. One of my friends suggested that I simply apply an adhesive roof covering that is used on flat roofs. (I think that it comes in rolls). Any suggestions?
Thanks,
Dennis
dwlodyka is offline   Reply With Quote
Old 08-11-2008, 02:53 PM   #2
Registered User
Termite's Avatar
I don't think that there's too many products out there that will be durable enough for use on a door threshold. Adhesive products won't keep water from getting into the threshold in this application anyhow.
A good sanding, a coat of primer, and a couple coats of high-durability oil-based paint might buy you some time.
I'd just save the effort and replace the threshold with a new one.
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Plastic threshold on new patio doors? firefly Building & Construction 8 08-23-2007 10:44 PM
Threshold between tile and vinyl tzibello Flooring 1 06-30-2007 08:42 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
