Threaded Rod Vs Bolts Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2014, 11:13 PM   #1
Rewards Points: 16
threaded rod vs bolts question
Hi,
I'm unable to find an exact hex bolt (galvanized ) I need....3/8x9".
The big box stores carry 3/8"x8" max.
Would galvanized threaded rod be an ok substitute ? The application is fastening through a swingset beam into heavy duty swing hangers.
I would put a double nut and washer on each end of the threaded rod.
Is there a difference between threaded rod and "galvanized electrical support rod?"
Like at HD bog box
http://t.homedepot.com/p/Superstrut-...038/100207537/
otherwise I will just countersink 1/2" into the swing beam support.
thanks!
maxim1 is offline   Reply With Quote
Old 07-31-2014, 09:01 AM   #2
Rewards Points: 626
Originally Posted by maxim1 View Post
Hi,
Like at HD bog box
thanks!
Go to fastenal it is a warehouse store that stocks every kind of nut bolt and screw ever made.
http://www.fastenal.com/web/home
there is their link hope that helps.
Nailbags is offline   Reply With Quote
Old 07-31-2014, 09:02 AM   #3
Rewards Points: 14,312
If you want it Heavy duty you should have been using 1/2" not 3/8", then you would be able to find them long enough.
Why are you not using carriage bolts instead of hex bolts?
Old 07-31-2014, 09:22 AM   #4
Rewards Points: 16
Fastenal only carries SS in that length, it is a possibility...but $6 each for a bolt. Carriage bolts don't come any longer, and I didn't actually think there was a difference other than the rounded head.
Plus with a hex bolt I can put a socket on both sides. Is there a good reason to use carriage bolts? Nothing is tightened down yet.
So is the threaded rod not as good?
Old 07-31-2014, 09:27 AM   #5
Rewards Points: 2,100
ACE hardware will probably have a 3 or 4 ft stick of 3/8 fine thread and fine is what you want being it is stronger than coarse. If you use red thread locker rather than jamb two nuts, a single nut won't move and the threads at that location will never rust.
Old 07-31-2014, 10:05 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
Threaded rod is fine. Used all the time.
Only real advantage to a bolt.....easier to install.
ddawg16 is online now   Reply With Quote
Old 07-31-2014, 02:01 PM   #7
Rewards Points: 392
I wouldn't use threaded rod on a swing set because it's generally soft. You need to use proper hardware because a swing set can seriously hurt or kill someone if it comes apart.
rustyjames is offline   Reply With Quote
Old 07-31-2014, 04:15 PM   #8
Rewards Points: 410
You need to look a little harder at the Fastenal site.
SKU 11131 @ $1.82 3/8-16x9 hex bolt
SKU 21381 @ $1.23 3/8-16x9 carriage bolt
Hot dipped zinc will be more $ but worth it for outside use IMO
1/2" is available also in these length's.
A carriage bolt is customarily used on wood but don't quite know what your trying to do here.
A pic would be nice.
High Gear is offline   Reply With Quote
Old 07-31-2014, 04:24 PM   #9
Rewards Points: 392
And if the swing set is constructed with treated lumber you should be using Hot Dipped Galvanized (not zinc plated) hardware, at the very least.
Old 07-31-2014, 06:15 PM   #10
Making this way harder then it needs to be.
Never have seen fine thread galvanized threaded rod, and there's no need for it in this application.
Threaded rod, and carriage bolts are all going to be grade 2. Which will work fine for shear strength.
Just use 1/2 carriage bolts.
Makes you some how feel better use galvanized lock washers.
ddawg16 (07-31-2014)
Old 07-31-2014, 06:48 PM   #11
Rewards Points: 16
I saw what you were saying....hot dipped galvanized 3/8x9... found them....thanks
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 10:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
Anchor bolts not sitting properly in wall HandyCapped Concrete, Stone & Masonry 3 04-15-2012 08:15 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
