Threaded Pipe Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 09:06 AM   #1
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Question
Threaded pipe corners
The best way I can describe this project is I need to make half a cube out of threaded pipe and attach it to the wall at the ceiling with threaded flanges.
However, I am having a hard time finding the corner fittings that I need.
In one place, I want a corner - three openings at right angles to each other, to make the corner of the "box."
However, somewhere else, I need the corner to also have a threaded end out the side, so the pipe can continue. Like a T. Any ideas where I would find that in 3/4? Or the proper name of it so I can search online?
THANKS!
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 03-11-2013, 09:14 AM   #2
mnp13's Avatar
Rewards Points: 512
Here is what I mean, in case you can't read my mind! lol
Michelle
Old 03-11-2013, 09:22 AM   #3
joed's Avatar
Rewards Points: 11,966
Don't know that you find the corner fitting. The closest I have seen is a cross fitting.
Try goggling "pipe fittings".
Old 03-11-2013, 09:23 AM   #4
mnp13's Avatar
Rewards Points: 512
I did that, I've looked through about six different websites so far. Haven't found anything.
Michelle
Old 03-11-2013, 09:24 AM   #5
mnp13's Avatar
Rewards Points: 512
Oh, I found the corner fitting. (On the right in my sketch) it's the one on the left that I'm having trouble with.
Michelle
Old 03-11-2013, 09:36 AM   #6
mnp13's Avatar
Rewards Points: 512
FOUND IT!
Well, the name anyway. It's a "side outlet tee" in case anyone was wondering.
Michelle
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 10:23 PM
Old School Cast Iron Pipe Repair turkboy Plumbing 14 06-28-2012 07:50 AM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
