Thoughts On Basement Systems Waterguard (Having No Pitch A Problem?) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 04:46 PM   #1
Rewards Points: 16
Thoughts on Basement Systems Waterguard (Having No Pitch A Problem?)
I have some water issues in the basement. Nothing too major but enough where I want to install an interior drain system. I had Basement Systems out and they recommended their Waterguard system.
I like the idea but hate the $8k price tag. Now, luckily, I actually found a guy who is selling the waterguard materials. So I really think Im going to do this myself.
The question I have is since the Waterguard sits on the footing, which "should" be level, would this hinder how well it works? If its level id think youd just have water sitting there instead of flowing consistently to the sump pump.
http://www.basementsystems.com/basem...aterguard.html
JakeFV is offline   Reply With Quote
Old 05-01-2011, 05:24 PM   #2
Civil Engineer
Rewards Points: 4,940
Water flows downhill with respect to water level, not with respect to the level of the pipe. As long as the water level in the sump is lower than the water level in the pipe, which it certainly should be (that's why you put a pump in there), the water in the pipes will drain just fine to the sump even if the pipes are dead flat. In my commercial jobs, I normally specify flat pipes for the perimeter drain, it works fine.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
JakeFV (05-01-2011), operagost (05-02-2011)
Old 05-01-2011, 05:27 PM   #3
Rewards Points: 16
Thanks Daniel.
Out of curiosity. Is there anything else I could use that besides a jackhammer to dig through the slab next to the inside of the foundation, down to the footer? Id just have a feeling that itd be too powerful, and be too easy to damage the footing.
Old 05-11-2011, 10:37 AM   #4
Hi JakeFV,
You won't have a problem if you locate the sump pump in the low spot of the basement. Also, be careful that what you're getting is actually WaterGuard. It's a product that is only available to authorized Basement Systems Dealers and is not for retail sale. The 8k price tag is due to the amount of work it takes to install correctly in a basement, including an appropriate sump pump system with discharge line. There are also other challenges that may arise while installing, which Basement Systems installers are extremely trained and experienced at handling. You could use a concrete saw, but in my experience it takes much longer than an electric jackhammer. Another issue is that creates a smooth line in which the new cement can shrink away from the original floor after curing. The jackhammer leaves more of a jagged edge for the new cement to bond to. Keep in mind, you're also not getting discharge line protection, or a warranty! Good luck!
WaterWizard is offline   Reply With Quote
Old 05-20-2011, 12:39 PM   #5
Where did you find someone able to sell the WaterGuard System?
bigdave007 is offline   Reply With Quote
Old 05-20-2011, 01:04 PM   #6
Rewards Points: 4,796
pumps are ALWAYS placed in the bsmt's low spot - the sump there are extrusions on the market who may be the supplier for bsmt systems for all i know,,, 'WaterGuard' may be a trademark but we use the same mtl,,, its actually easier/faster/less expensive installing the bsmt sys - much less excavation compared to the traditional pipe under the floor, miradrain, drain holes in the block's cells, no filter cloth.
we would rather take bsmt waterproofing jobs than conc here - MUCH more profit & equipment's cheap ( rent a bosch brute ),,, IF you want a neat line, sawcut 1" deep 1st then use the brute to open the floor ( btw, dri-diamond = LOTS more dust & wet saws are messy ) any conc shrinkage will occur whether or not the line's straight or jagged,,, the above poster's referring to 'mechanical interlock' - neither prevents shrinkage in my 39yrs,,, the $8K price is another issue - sumps cost 59 incl cover, zoeller pumps are about 175 at ferguson/grainger/ebay ( m53 ) check valve $10, + 1 1/2" discharge pvc pipe, & no one gets a deal on sackcrete.
yes, their installers have experience - they should as its their work ! but its only rocket science when you're building rockets - keep in mine your objective is to MANAGE leaking water & direct it to a low spot ( sump ) whereupon your pump takes over - caution - float switches aren't as reliable as zoeller's mechanical mounted on stainless/steel guides
think wizzy may be/have been on the sales side 1 time or is now ?,,, that's just a guess,,, ck some other pricing in town - we're usually 1/2 of their pricing however we don't have the same ovhd NOR do we use commission'd reps,,, IF you aren't up to this physical challenge, maybe you're more talented at buying beer & cajoling friends,,, bsmt waterproofing's most significant invention in the last 30yrs is a better 5gal plastic bkt
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Concrete Problem in Basement!! pilotandy72 Building & Construction 3 07-31-2007 03:19 PM
Plan for solving basement moisture problem krx Remodeling 1 12-04-2005 07:00 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
