Thoughts Around Basement Renovation Quote - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 07:06 PM   #1
Thoughts around basement renovation quote
Hi,
After getting terrified with a $36,000 quote for renovating the basement - 390 sq ft, I need to get your opinion on the new quote. THis does not include plumbing, or tiles, toilet, doors, sink, faucets. The cost is about $50/sq ft.
Size - 390 sq ft.
1 bedroom - 10x10
1 - 2 piece washroom
install drywall, insulation,
no finishing
there are 3 doors - 1 bedroom, 1 washeroom, 1 in the furnace area which iwill be closed off.
There is no moving walls, or pipes (which is plumbing).
building materials are provided.
I think the price is very expensive given that it is a very straight forward job. The basement is bare right now, so there is no behind the walls surprises. There is no electrical work other than lighting wiring - electrical box stays in place, only needs to be boxed in.
Thoughts?
Thanks so much in advance.
Nerina
What do you think?
NeriN. is offline   Reply With Quote
Old 03-26-2011, 09:27 PM   #2
firehawkmph's Avatar
Rewards Points: 1,800
Neri,
A lot depends on where you live and what the actual project entails. Initially it sounds like a lot, but without the rest of the details, it's hard to say. Why not check around for another contractor or two based on satisfied recommendations from past customers.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-26-2011, 10:17 PM   #3
thanks Mike. actually it just entails drywall, 3 door frames and covering ceiling and subfloor. I have a plumber doing washroom stuff. I'm in Ontario north of toronto. I will ask around but after having done many renovations in 3 different houses, I am not very trusting of contractors. btw, I'm female, so I suspect that there might be an automatic upcharge when they read "I'm gulilble" on my forehead
Old 03-26-2011, 11:18 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Does the bedroom have proper egress?
Cabinets?
what does no finishing mean?....no paint or no tape, sand and finish?
Stairs?
Hard to say if it's expensive or not.
Reputable contractor? been around for a while?
How'd you get him to give you a price?
Does he know that the plumbing, tile and doors are not part of his scope?
I'd get a second or even third estimate too.
tcleve4911 is offline   Reply With Quote
Old 03-26-2011, 11:45 PM   #5
Rewards Points: 1,016
Three estimates will usually give you a good idea of pricing for a job. You have to ensure you give the same requirements to each prospective provider to ensure you are comparing apples to apples. After I get the three prices, if I have one especially high/low I go back to that provider and ask them to help me understand why thier price differs from the others substantially.
Insulating basement - questions jtmann HVAC 7 11-19-2010 04:20 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
basement renovation yummy mummy Remodeling 156 05-08-2007 11:15 AM
