Thoroseal In Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 10:19 AM   #1
Thoroseal in basement?
I have an old (1878) brownstone row house on a corner lot (3 walls have dirt next to exterior side, 1 is shared with adjacent house) and am having waterproofing work done in the basement. I'm having floor replaced with vapor barrier, new cement and repointing the walls (foundation walls are large stones, pillar in middle of basement is brick). One contractor recommended applying Thoroseal after repointing, while another said it would trap moisture and cause the mortar to deteriorate. I do not have a serious water problem, but there is some moisture on one wall after heavy rain. Would appreciate recommendations. If you don't recommend Thoroseal for walls, would it be OK to apply to the brick pillar? What about wall shared with next door house. Thank you, Mike
tofino is offline   Reply With Quote
Old 10-26-2010, 11:18 PM   #2
Rewards Points: 1,092
If there is water getting into a wall, and it sounds like it does get into yours, then let it dry; do not seal the wall on the inside. It is best to go outside and seal the wall there, letting it breathe to the inside; latex paint, if you paint it. As for the shared wall, I don't see any moisture issues if you both have fairly warm, fairly dry walls. Again, I'd use latex paint to let it breathe a tad. Certainly vapor barrier your floor, and "goo" the vb to the walls so you don't have moisture wicking/oozing in from the ground. If the old brick pillar is in contact with the ground, latex paint. It will be wicking water up; let it dry. j
Tags
basement , waterproofing
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
