#1 |
Thinstone on sheathing 3/4" off of the foundation
Hi I have asked a few people but no one can give me a straight answer...
I am doing about 125 sq ft of thin stone on the front of my house. There is about 2.5' of foundation around the house. I plan on going from the sheathing down to the base of the foundation. The issue I am trying to figure out is this... The sheathing goes over the foundation about 3/4" so if i just put up the metal lathe all the way down the stone will look to "cave" into the foundation. I was told to try to add more mortar to level it out to the sheathing, but that seems like it would be a lot of mortar between the foundation/wire mesh to the stone itself.. about 1.25" (3/4 to even to the sheathing then 1/2 for the scratch coat) Any help would be great full, here is the type of stone I am using.. http://www.connecticutstone.com/thin...e-overview.php Craig Last edited by Kasper; 08-27-2010 at 10:54 AM. |
#2 |
You would nail or screw furring strips to the foundation to level the surface. The wire lath would be attached to the the wood strips. Apply a scratch coat to the lath and apply the stone to that. Heavy stone will require a base to keep it in place.
Ron |
#3 |
Concrete & Masonry
I think I may know exactly what you're asking, but a picture would sure help remove doubt......................
#4 |
Thinstone on sheathing 3/4" off of the foundation![]() Im not really sure nailing furring strips into the foundation would hold enough? wouldn't ramset type of anchor screw work a lot better?, a little more time consuming though Last edited by Kasper; 08-27-2010 at 10:18 AM. |
| Display Modes | |
| Round House Foundation Feasibility | Mswick | Building & Construction | 23 | 02-27-2010 09:34 AM |
| Replacement concrete garage floor, dowelled into foundation? | Niffumdutz | Building & Construction | 5 | 02-19-2010 09:31 PM |
| Foundation Repair Help | rasilun | Remodeling | 1 | 10-15-2009 11:26 PM |
| How to add footing and foundation to existing foundation? | ptcamaro | Building & Construction | 6 | 06-22-2009 11:22 AM |
| Floor Joists Lifting Off Foundation Walls?! | cbeingessner | Building & Construction | 2 | 06-12-2008 09:39 AM |
