Thinning Joint Compund - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 01:52 PM   #1
I bought a box of premixed all purpose joint compound to finish my garage. Should I mix a little more water into the mud before I use it, or should I use it directly out of the box?
This is what I've got:
Also, can I use this mud as a final coat also, or do I need topping mud for that?
mopowers is offline   Reply With Quote
Old 08-25-2009, 03:06 PM   #2
I usually thin mine with a little water and you can use it for your bedding and top coats.
Jim Hart is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Can't get ball joint to separate from knuckle on '88 R10 1/2 ton 2WD Suburban TJMS81 Automotive Repairs 11 11-27-2009 10:11 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 08:10 PM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 11:56 AM
