Old 04-18-2009, 02:54 PM   #1
Thin pine paneling instead of sheetrock
I just joined this place, which seems to be a wonderful resource.
I am about to finish the garage as a shop. I can get my hands on 5/16 T&G paneling pretty cheap, and I wonder if I could put it on part of two walls, on the corner where I will have the woodworker bench. The studs are bare, 16" OC. Is this material too thin to apply direct over the studs?
rdy2go is offline   Reply With Quote
Old 04-18-2009, 03:10 PM   #2
You could staple paper to the studs. Is your question what is the best way to apply this, or are you looking for approval of this material as a finish?
It ain't Rocket science unless you are building rockets
Tscarborough is offline   Reply With Quote
Old 04-18-2009, 06:07 PM   #3
My first concern is if this material without sheetrock behind will have enough rigidity.. is not like it is 3/4" T&G.
As for the installation, are you talking plain brown paper of roofing paper? I assume the insulation paper will be on the surface. I am still thinking about the insulation. The walls have 2x4s but the bottom plate is 2x6, so I was thinking on glue/finish-nailing 6" pieces of 1/5" ply every 16" or so and then 2x2 nailed on top thru the ply into the stud. That would allow for R21 which here in Minnesota would help. I do not know if 16" spacing for the ply spacers is enough, or could I go to 20" or 24". The more space, the better thermal separation. Am I in the right track?
More On This Topic
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
This is Shannon Kniep on behalf of Expert Village. Before you put your sheetrock on, you want to go ahead and make sure that you've got everything taken care of because you're going to cover it up. In this case, we need insulation on our pipes--this is a... Read More »
Replacing insulation is an easy and money saving way to reduce your home's heating and cooling costs. People with good fiberglass insulation installed will never have to replace the insulation again. The easiest time to replace insulation is during home... Read More »
This is Shannon Kniep on behalf of Expert Village. Now that we have the sheetrock in place; insulation in place, we're going to try to prepare the edges. Now this is sort of makeshift, because we are matching brand new with old. This has texture on it... Read More »
My name is Shannon Kniep on behalf of Expert Village, I'm going to show you how to cut a piece of sheetrock. We got the measurements up on our ceiling which is what we need in order to know the size of the piece that's going to fit in there. And it is... Read More »
Dried out knotty pine paneling lsurface1 Carpentry 9 06-14-2009 11:39 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Can't find studs behind knotty pine paneling David S General Discussion 11 12-10-2006 11:15 AM
knotty pine paneling harleyd1369 Carpentry 3 11-19-2006 12:01 PM
knotty pine paneling Unregistered Remodeling 1 04-05-2004 02:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
