-   -   Thickness of cement board on plywood ceiling (http://www.diychatroom.com/f19/thickness-cement-board-plywood-ceiling-52808/)
hacksepe 09-11-2009 01:02 PM
Hi
I'm building a steam shower in my basement in place of the old tub enclosure (part of redoing the bathroom).
I've ripped everything out and re-framed the walls. On the ceiling I have solid 8" joists a little irregularily spaced due to a fireplace above (It's a 1920's home). To prepare for the tiled ceiling, I screwed 3/4" plywood under the joists, and planned to put permabase cement board on that. Originally I planned for 1/2", but now I'm wondering if 1/4" is enough given that I am attaching it to 3/4" plywood. Normally ceilings are supposed to be 1/2" cement but with a plywood backing, would 1/4" not be enough? Alternately I could use 1/2" plywood and 1/2" cement board, but plywood adds more strength than cement board.
My motivation is that the ceiling is a little on the low side. Not sure if it is weakening things for 1/4" gain in height. I plan to kerdi over the whole thing, so I am wondering if that wouldn't be enough or should I stick to my original plan?
Termite 09-11-2009 01:17 PM
Provided you set the backerboard in thinset to the plywood (as you should) and secure it to the plywood with plenty of screws, I don't see any reason that 1/4" would be a problem.
hacksepe 09-11-2009 01:32 PM
How would you recommend applying the thinset? The plywood is on the ceiling now. Should I apply it to the back of the cement before screwing it in? How thick should the layer of thinset be?
Thanks!
Termite 09-11-2009 05:07 PM
Use a square-notched trowel...I'd say 3/8" notches would be fine. You can apply it to the ceiling or to the sheets I suppose.
Ron6519 09-12-2009 08:46 AM
Thanks!
I'd apply it to the plywood. It would add weight to the cement board.
Ron
hacksepe 09-13-2009 07:07 PM
I applied it to the cement board and it was pretty easy to put up. My wife and son lifted into place and I screwed in the concrete screw. It worked out just great, Thanks!
