Thick Leveling Mortar Bed OK For Concrete Block Stem Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 04:06 PM   #1
DIYer
Rewards Points: 93
Thick leveling mortar bed OK for concrete block stem wall?
Im building a small shed. Id like to build a two concrete block tall stem wall. Ive poured the footing but unfortunately its not level. At its worst, it would need about 5 inches of a mortar bed to level it out.
Is this within spec for mortar? I will be reinforcing the mortar bed and above course with wire weld mesh and with vertical rebar already set in the footer
Thanks in advance for your advice
dwoloz is offline   Reply With Quote
Old 02-20-2011, 05:08 PM   #2
Rewards Points: 1,092
I can't imagine good concrete having any problems from the loads of a small shed, myself. I'd pour it and go. How in the heck did you miss by 5"?
Old 02-20-2011, 05:30 PM   #3
DIYer
Rewards Points: 93
I really don't want to mess with setting up forms so Im going with blocks
I originally intended to do a poured wall so I was not careful with the level of the footing, figured it would sort itself out in the pour and Id make sure the forms were level. Ended up being a bonehead move, I have plenty of those
Old 02-20-2011, 08:46 PM   #4
Been there, done that. j
Old 02-20-2011, 09:08 PM   #5
I had a similar thing happen (not 5" though) and had a hellish time getting the blocks level and true.
I would advise you to pour a concrete leveling course on top of your footing, then lay your blocks on this!
Old 02-20-2011, 09:23 PM   #6
Buying the first round
LIHR's Avatar
The good news is you made a mistake on a not so critical project.
I agree with Wildie and pour a level bed. It will be challenging to say the least to build up a mortar joint that thick. The slump and weight of the block, along with the laws of gravity will test your patience.
You could also cut the block with a gas powered masonry saw and taper them.
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 02-20-2011, 09:44 PM   #7
DIYer
Rewards Points: 93
Thanks for the replies
Maybe I need to overcome my fear of forms and just do it. If I have to pour more to level it I really might as well just pour the wall
Any tips? I plowed through library books but found them unhelpful; most explained the form process for large basement walls
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 12:11 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 08:47 AM
