Old 01-05-2013, 01:00 PM   #1
Are these studs likely loadbearing? Can I move one?
I'd like to move (or remove) one or two of the center studs to make enough room for a person to comfortably walk under the stairs to access storage.
Does it look like the two studs marked 1 and 2 are likely loadbearing? If so, Could one be moved just enough to make a 24-30" space?
Are these studs likely loadbearing? Can I move one?-studs.jpg   Are these studs likely loadbearing? Can I move one?-under-stairs-view.jpg
mrreoweh is offline   Reply With Quote
Old 01-05-2013, 07:58 PM   #2
Safe answer seems to be that 1 and 2 studs support a landing that supports both upper and lower staircases, so I would leave them there. I can't see enough of the whole structure to suggest something else.
carpdad is offline   Reply With Quote
Old 01-05-2013, 08:09 PM   #3
#1 There was suppost to be 5/8 fire rock under those stairs.
#2 Just make a door way in the side wall.
Old 01-05-2013, 08:10 PM   #4
STAFF
BigJim's Avatar
I really don't see a problem removing #1 or #2 cripple, not both though. You really need to install a header at the top of your stairs there is just not enough support for the three stringers at the top.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
joecaption (01-06-2013)
Old 01-06-2013, 10:50 AM   #5
are those stringers installed correctly ? looks to me like they are not.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 01-07-2013, 06:20 PM   #6
GBrackins's Avatar
I hear ya Big Jim & Fix'n it .......
guess they stay up because they're used to being there, looks like the stairs could use a little TLC.
a proper header above #1 & #2 supported by the studs on the side would work. I'd certainly take care of the issue at the top of the stringers as you currently have little support
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
BigJim (01-07-2013)
Tags
loadbearing, stairs, studs
Load bearing section - gap in studs AppleMac*Fit Building & Construction 21 08-09-2012 02:32 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Unsure of best way to mount studs. Brandnewruins Carpentry 6 04-24-2009 05:12 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
