-   -   Are these studs likely loadbearing? Can I move one? (http://www.diychatroom.com/f19/these-studs-likely-loadbearing-can-i-move-one-168307/)
mrreoweh 01-05-2013 12:00 PM
2 Attachment(s)
I'd like to move (or remove) one or two of the center studs to make enough room for a person to comfortably walk under the stairs to access storage.
Does it look like the two studs marked 1 and 2 are likely loadbearing? If so, Could one be moved just enough to make a 24-30" space?
carpdad 01-05-2013 06:58 PM
Safe answer seems to be that 1 and 2 studs support a landing that supports both upper and lower staircases, so I would leave them there. I can't see enough of the whole structure to suggest something else.
joecaption 01-05-2013 07:09 PM
#1 There was suppost to be 5/8 fire rock under those stairs.
#2 Just make a door way in the side wall.
BigJim 01-05-2013 07:10 PM
I really don't see a problem removing #1 or #2 cripple, not both though. You really need to install a header at the top of your stairs there is just not enough support for the three stringers at the top.
Fix'n it 01-06-2013 09:50 AM
are those stringers installed correctly ? looks to me like they are not.
GBrackins 01-07-2013 05:20 PM
I hear ya Big Jim & Fix'n it .......
guess they stay up because they're used to being there, looks like the stairs could use a little TLC.
a proper header above #1 & #2 supported by the studs on the side would work. I'd certainly take care of the issue at the top of the stringers as you currently have little support
