Thermal Insulation Under Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2007, 11:27 PM   #1
Rewards Points: 1,062
thermal insulation under concrete
i am lowering my basement and someone told me that it would be a good idea to set some foam thermo insulation on top of the dirt or gravel before laying concrete. is this truly the case ? if so, what kind should i get ?
thx,
- a
Old 07-13-2007, 11:43 PM   #2
RippySkippy's Avatar
Get the kind rated for under slab, either the Owens Corning Foamular 250 or the Blue Dow foam. Lowes has the Dow board, and Menards has the Owens Corning. For what it's worth, while your at it...I would add a 6 MIL vapor barrier under the foam, it virtually eliminates the moisture migration through the slab.
Have you though about laying radiant heat pipes...even if you don't hook the manifold up now...it would be ready if you wanted it later.
RippySkippy is offline   Reply With Quote
Old 07-14-2007, 12:24 PM   #3
Question
thanks. does it go b/ween dirt and gravel or gravel and concrete ?
Old 07-15-2007, 07:53 AM   #4
Level fill, vapor barrier, insulation, concrete.
Old 07-15-2007, 08:39 AM   #5
General Contractor
joasis's Avatar
We have a company locally that will spray foam on grade, 1 inch, for an R7 value and is also a vapor isolation. $1.20 a sq/ft installed.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 07-15-2007, 09:13 PM   #6
Is that uniform enough to pour a floor over? Sounds interesting...do you have any pictures?
Old 07-15-2007, 09:50 PM   #7
what is vapor barrrier ?
Old 07-16-2007, 07:39 AM   #8
Read up: <http://findarticles.com/p/articles/m...9/ai_114818845>
Old 07-16-2007, 07:51 AM   #9
Rewards Points: 5,336
When I had the crawl space rat slab poured, I put down 2" polyisocyanurate board down. I called the manufacturer and they said to put plastic on both sides of the foam. This product had foil on both sides.
Ron
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
insulation b/ween concrete and gravel in live-in basement amakarevic Building & Construction 6 08-15-2007 01:02 PM
Insulation over concrete slab sandyman720 Building & Construction 4 04-29-2007 12:24 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
