Old 01-04-2013, 05:11 PM   #16
Moderator
Thermal bridging
What type of sheathing- OSB or plywood? Any block in that wall?; http://publicecodes.cyberregs.com/ic...016_par015.htm
Gary
PS. You can also cut 1-1/2" wide strips of XPS for on the studs/plates before the drywall...ADA the drywall to limit air movement.
Clothes taking longer to dry?
Metal or wood cross bridging Mijotter Building & Construction 17 01-11-2013 02:49 AM
Mid span bridging lylsutherland Building & Construction 2 10-30-2012 12:10 AM
Bridging between joists cortell Building & Construction 0 01-03-2011 09:11 AM
Electrical Baseboard Thermal Protection Blade_316 Electrical 5 10-22-2009 06:51 AM
Thermal Zone Ductless Minisplit wrldruler HVAC 3 02-23-2009 06:31 AM
