Thermal Break - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 07:23 PM   #1
Thermal Break
Here's what I have...
Current situation: A breeze way in between garage and main house with the exterior door in between. (See attached)
Modified situation: The door pictured will be eliminated and a new door will be faced on the front set back a couple of feet to maintain a little overhead, but will now enter in to a mud room (see attached for the plan)
My question is this...does a therma break need to be installed (cut into the existing slab) at the door sill?
Thanks for your help!
mykquin is offline   Reply With Quote
Old 11-11-2011, 08:15 PM   #2
Rewards Points: 502
You'll always have an uninsulated underneath your mud room, unless you lift it up and insulate underneath the new sub floor; or tear out, insulate and re-pour the slab there. I'd leave the exterior door in place if I were you. the mud room will still be quite a bit warmer than the old breezeway in the winter, but it would be an unheated area.
have you considered the insurance ramifications of this alteration?
forresth is offline   Reply With Quote
Old 11-11-2011, 09:02 PM   #3
The new mud room will have heat coming from the kitchen and we're considering radiant heat under tile as well as insulation throughout. Will also be insulating the garage at some point next spring.
Not sure I catch your meaning about insurance ramifications?
Old 11-12-2011, 08:13 PM   #4
Registered User
Rewards Points: 526
You will want to isolate the entry slab from the garage bricks for a thermal/capillary break.
The wall bricks will wick the heat from the room to the colder garage and house walls.
Re-routing the hood fan ? through the new space may be a challenge. At least you will solve the mold problem and ineffective flashing.
Gary
How to fix thermal break in cinder blocks tsg234 Carpentry 2 07-15-2011 12:32 PM
Thermal audit on new build (thermal pics) danreg99 General DIY Discussions 0 03-14-2011 07:38 PM
Thermal Zone Ductless Minisplit wrldruler HVAC 3 02-23-2009 05:31 AM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 04:46 PM
Thermal Break For Tile fierysun Flooring 2 03-06-2008 06:22 PM
