There's A Well In My Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 03:25 PM   #1
There's a Well in My Crawl Space
Just found out that the house we recently purchased has an open shaft (hand dug I suspect) well smack dab in the middle of my crawl space. Evidently it has been there since the 1930's when the original home was added on to.
Can I just cover it (seal it) and forget it?
Don't know how deep or diameter of it yet but that is on my list of things to find out.
Filling it would be one major project!!
Butchiss is offline   Reply With Quote
Old 06-17-2011, 03:39 PM   #2
Too Short? Cut it Again!
Sounds like it might not be a well but an old cistern. If so, and it is more or less structurally intact, you can probably leave it alone so long as you seal it off at the top for safety reasons (pets, kids, etc. falling down into it). The best thing would be to fill it in though.
Old 06-17-2011, 05:32 PM   #3
Rewards Points: 40
If it really is a well, it will have to be destroyed (filled in) properly to prevent polluting the groung water. Check with a reputable well driller in your area, as filling it in might not be allowed as DIY. A cistern can probably just be filled in, but again a driller in your area will know for sure.
daveb1 is offline   Reply With Quote
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Crawl space moisture/water removal KAdams4458 Building & Construction 7 04-24-2011 12:21 PM
Old Septic pipe flooding into crawl space ktipton Plumbing 2 04-14-2011 02:18 PM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 07:52 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
