Is There A Payback For Higher Level Insulation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2007, 09:40 AM   #1
is there a payback for higher level insulation?
This may be a bit theoretical, but I am trying to figure out if the additional cost of foam board insulation and higher R value compared to fiberglass is economical and provides a good return on investment over time, ie by figuring savings in heating cost into the equation.
here the facts:
- I am looking to put new insulation into my attic roof
- The attice room will be used as liveable space
- I live in zone 1 as defined by the DOE - recommending R49
- 1 sq foot of R38 in fiberglass cost about 80 cents (before tax)
- the same insulation using foam Boards is about 3$
- the total roof is about 600 Square foot
here is the situation - if I have enough depth in my rafters I would go for fiberglass as it is more economical, however my rafters are only 6 inch deep to the roof
so I am trying to figure out, if I spend more money on the more expensive foam boards, I can achieve an higher R value and insulation, which over the years should save on my heating bill
How can I calculate the savings I will get with each R I increase, ie how much heating bill savings can I expect when I increase insulation by 1 R (assuming the formular is linear, I can calculate my return on investment for different thickness of foam baord as options)
hope this makes sense, I am sure this is not an exact science, but I am looking for some rough estimates to help me with the decisions....
thanks, Chris
walenta is offline   Reply With Quote
Old 10-25-2007, 11:44 AM   #2
Rewards Points: 5,336
Use a combination of foam and fiberglass. Build out the rafters so you can get R-19 in there with a air gap and go over it with the foam of whatever thickness you want. The thinner foam will reduce the overall cost.
There is a rule of diminishing returns on the insulation. You will see a payback, but at a certain point it will take longer then your life span. But the way energy prices are going up, maybe not.
If you want a more precise estimation, try your local utility, some of them will do a free energy audit.
Ron
Old 10-25-2007, 02:07 PM   #3
I'm with Ron. Put in R19 glass, and then fasten an inch or inch and a half of rigid foam over that. It only adds r-5 per inch, but the real world performance is better than fiberglass, when you account for settling, and thermal bridging with all those wooden rafters.
NateHanson is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 11:27 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
