Texturing Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 12:38 AM   #1
Texturing Stucco
I wonder if anyone on here is familiar with the texture in the photo and can give any tips on matching. I'm repairing a section of stucco below the patio sliding door and I want the texture to match the existing texture of the house which is what is in the photo.
I recently did another repair and I also wanted a match so after the top coat I dipped a masonry broom in the stucco and used to to create blobs like in the photo - the problem was when I tried to knock it down with a trowel it kept crumbling off. In the end I used bigger blobs to be able to knock it down - the finish is a close match but not identical to the original. I would like to get the finish to look closer to the original.
blue_can is offline   Reply With Quote
painting stucco sorta myself AdamBNYC Painting 1 08-16-2010 08:17 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
