Textured Drywall Ceiling - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 07:21 PM   #16
Drywall contractor
Rewards Points: 1,068
Looks like it's just thinned down joint compound rolled on with a heavy nap (3/4" or 1") roller to me....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-17-2009, 11:29 AM   #17
I just got done covering up an old popcorn ceiling with new drywall that I finished smooth. I glued and screwed it (just be sure to get longer screws to go through the old layer and get a good bite in the joist). I would definitely agree that you should use 12' sheets if possible to limit your seams and cut the panels a little short (if your walls are already up) so you have room to maneuver the new panels up with a lift (new crown should cover up the gaps). I would also recommend putting additional blocking on your joists so you have a large margin of error when in comes to lining up the edges of your panels. It also helped me to go into the attic and drill holes along the edges of the joists through the old drywall to give me a point of reference when hanging the new panels. I HATE popcorn ceilings, so it was worth it.
bsperr is offline   Reply With Quote
Painting a textured ceiling computerdude103 Painting 4 06-28-2009 12:43 PM
painting over a textured ceiling tmtch540i Painting 1 04-04-2009 07:00 PM
What is the best way to paint a textured Ceiling? earthad1 Painting 8 03-18-2009 09:14 AM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 06:14 PM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
