Termite Damage In Top Plates, HELP - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 02:14 PM   #1
Rewards Points: 337
termite damage in top plates, HELP
So we are in the remodel from hell. I just thought we were coming around the corner, when my drywaller calls me downstairs and shows me jacked up top plates from termites. It's on the ground floor of a two story home on the exterier load bareing wall. We just had the new nail fin windows installed and we decided to replace the drywall since we had resized windows. In some areas it's really torn up. Others not as bad, we are talking about 40 running feet of double and triple 2x4 top plate. I am assuming that it all must be replaced or at some point the house will start sagging? Makes me wish I never opened a wall.
I found about 6 feet of damaged top plate in the kitchen (same wall) but it stopped at the splice so I figured it did not continue for another 20 feet, it appears I was wrong.
Any suggestions?
titan7 is offline   Reply With Quote
Old 09-25-2010, 02:32 PM   #2
Chicago, IL
Michael Thomas's Avatar
See:
http://www.diychatroom.com/f14/how-d...ng-wall-21058/
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
SEMAC (07-25-2011)
Old 09-25-2010, 03:02 PM   #3
Rewards Points: 337
well, that's out of my league. So what would have happened if I nevremodled and did not discover this, the house would fall?
er
Old 10-07-2010, 01:55 PM   #4
Rewards Points: 107
had the same problem
We ripped out 2 exterior wall because they were bad, alot worst than yours. We built a stud wall about 2' inside to support the 2nd floor. we used 2 floor jacks to lift slightly the double uprite studs which had a plate on top. yours looks ok in the picture, you should use an ice pick to see if the wood is solid enough to support what is above. We had to replace the patio door so this worked for us, it was a small family room. We did take down the siding outside and completly rebuilt the 2 exterior walls.
jerzeedivr is offline   Reply With Quote
Old 10-07-2010, 06:11 PM   #5
Rewards Points: 5,336
More then likely these are subterranian termites, so they've been eating from the sill plate up. You need to determine where they got in, because that's where the damage will be the greatest. Generally the access points are the doors to the house. I'd start there.
Ron
How do I replace termite damaged top plate under trusses on a load bearing wall? durangorob Carpentry 7 07-25-2011 07:45 AM
Is this termite damage? snosurfa7 Pest Control 4 03-23-2010 01:50 PM
How to determine age of ... TERMITE DAMAGE ????......new or old??? Dyoung Pest Control 9 02-26-2010 08:32 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
How to Fix Termite Damage iammos Building & Construction 12 07-21-2008 03:58 AM
